I have the following problem:
I have navision 3.70 with its own database running on a windows 2003 server. The path where the database of navision was f:/a/f.fdb. I stopped the service and deleted the *.fdb file in windows explorer.
Then I wanted to start the navision 3.70 service an wanted to make three fdb files f:/db/d1.fdb, f:/db/d2.fdb …
My problem:
the navision service lets himself not start because the service runs with the old database path f:/a/f.fdb I also tried to uninstall that service and install it with an other name - same problem. What I write not the database parameter the service starts with the same database path as before f:/a/f.fdb.
Could I say Navision Service to start with no databse parameter?
server installasservice,servername=xxxx,database=f:/a/f.fdb,nettype=tcp…
Thanks for ideas!
