We have implemented security changes weeks ago to remove SUPER permissions from multiple users. Today one of those users is unable to run the Fixed Asset report due to the error “You do not have permission to run the ‘Design, Form, Basic’ System.”
I have to agree with Jonathan on this. Basically giving access tot he Object designer is somethign that is only for SUPER users, or at least trusted users. You need to train this user to run the report form a menu, and not directly from the object designer.
You guys are both right Jonathon & David. I was unsure of whether or not SUPER was required to access the Object Designer. Although the user in question is trusted, they should not be SUPER.
In Roles you can define design permissions on users (Report, Forms, etc). Look at System Object. You have “Design, Table, Basic”, “Design, Table, Advanced”, etc.
I never assigned them to end users, since all cases that I know users with developing permissions are SUPER. But you could try.
Thanks all, I’m going to avoid assigning those permissions then. I’ll recommend that the user use one of the reports within the system. If the available reports do not provide the needed data, is there a way to create a custom report?
Okay. I’ve found the report in the designer, but I am unsure of the steps to add it to the report menu. The particular report is FA Depreciation Book ID 5612.
