I have a problem with Navision 3.60 Client Installation on Windows Server 2003. The problem is that at the end of installation the installer performs a rollback of the installation and everything is uninstalled. I found that this problem occurs because navision installation program overwrites the file msxml3.dll installed by win2003 server with an older version. This affects also mmc (microsoft management console). The solution was to re-register the new version of that .dll file, but this doesn’t work. Any suggestions? Thank you very much, Adrian Banciu
Turn off Terminal Services - Terminal Server functionality. Tõnu
I cannot turn off TS because this is the way the users connect to the server. But you are right, this problem appeared when I activated Terminal Services on that server. Now I’m working to set the TS connection via a web-based TS site. But the problem still exists. I am waiting for your advices
Try to to copy/paste files from Navision installation CD to Program Files, System32 and Common Files folders. Works fine for me.
Read this http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=7779 or use 3.70 with latest hotfix
[quote]
Originally posted by adybanciu
I cannot turn off TS because this is the way the users connect to the server. BRRR Dear ady Turn off terminal while installing only - not the whole system [:D]. Good one - must remeber that [:p].
