We are having problems using Citrix Mataframe XP. These problems seem to have occurred for the first time after upgrading to Navision 3.60 but we are not sure about this. The following happens several times a week: A blue screen appears with the message STOP: 0x0000000A (0x3FFFF5EA,0x00000002,0x00000000,0x8042D8FE) IRQL_NOT_LESS_OR_EQUAL *** Address 0042D8FE base at 8040000, Datestamp 3d366b8b - ntoskrnl.exe Has anybody encountered the same problems ? Thanks for your replies, Ron Bouwmeester
Is this happenning with only one system or is random across many systems? We had a similar(not same) problem with other Versions using CM XP. We were able to address in some cases by reinstalling Client OS. Looks like Memory/Address problem, also need to check for ‘ntoskrnl.exe’. To what is this related and any reasons for same.
