Navision 2013 Report
my company Requirement is one report item ledger entry post then run filter document no. Item A,B Qty10,20 report run Item A 10 page And Item B 20 Page Page Breakup with Qty Please Suggest best solution i have Map Report Item Wise but not map item qty wise Please Help
Regards
Vicky
Can you please explain your problem?
Actually One Report with Page Loop Run Qty Wise
ILE Document No. 10000
Item A Qty 2
Item B Qty 4
Then Run Report Filter Document No. 10000
Item A 2Page Run
Item B 4 Page Run
Hi Vicky
Do you Got Your Report …If you want a only one Document No then Design a Request Page So that only Particular Document No is Filtered.
If You want all Document No then Group your Report With Document No So That It
First Document No will Printed then followed all Items And Then Next Document No… Respectively…
If You Need Any Help Let Me Know[:D]
