there is strange problem with the debugger on my pc, the code is shown in different format (non readable). i have uninstall and reinstall the navison but the problem is still persist. i couldn’t debug any code please suggest some solution for this.
Sumtime back I faced a prety much same problem(not exactly the same though), then I tried to find the zup file in the system and deleted the zup file then restarted the NAV then it was working fine for me.
(Note: Before you do the above check if you have the same problem in all machines or only particular machine, If you have that problem only in your machine then only try to do the above.)
