Navision 2009 Posting Sequence
Good day,
Could you please advise on the posting sequence at the time of converting a sales order to an invoice?
My system is not doing this sequentially
Go to Sales & receivable setup—> and look for Sales order No. series in numbering tab. Once you get the No. series code go to the No. series page–>Line Relationship–>You then set the Starting no. like SO-00001 and then check the increment field. Make sure Default no. series is checked true and Manual nos. if false.
Follow the same above step and this time look for S-INV, in here you will set the Posting no. series for Sales invoice, go to the No. series the in the S-INV go to the lines relationship and and set the starting no. SI-0001 and then check the increment field. Make sure Default no. series is checked true and Manual nos. is false.
Now when you post the Sales order SO-0001 you will have SI-0001 as the posted invoice as the posting will take the posting no. from S-INV.
Good day Sbhatbng,
Thank you kindly for taking time to detail the above.
Really appreciate.
Douglas
