Is there a way to change the way Navision links to documents? Currently you can only link to a file, we would like to link to a folder, then when the folder is opened via NAV we can view any document within this folder. This would enable a better organization of documents that are all related to a specific order # and allow other users to attach docs straight to the folder with out having to open Nav and link each doc as it is generated.
There is possibility but modification is required. Do you just want to open folder from Nav and view the files inside that folder?
Yes, that is exactly what we want to do. Several departments generate documents for an order, currently they have to save the doc to a folder then open NAV and link that individual file to the the order. The ability to only link a folder and then open it from NAV to view the documents in that folder would speed up our process eliminating the need to continually open NAV to link the associated documents.
