Navision 2.6B - Check Report using the wrong format
I am currently having some difficulties in modifying the format of the check report, which the voided check should be printed on the bottom of the page, but not right after the detail lines (while the older version: 1.2B was fine with the format of the check). I am not very sure if I need to set the detail lines to 10 lines as the maximum per report or not. What should I do? Thanks. Sylvia
Sylvia, what type of check forms are you using. We have them fitting the check and have also done mods for 2 stub checks. Soren Nielsen, moderator Integration/Developer NOLUG
