Hello Folks, I have tried to connect the Navision database via Php3 and the ODBC Driver 2.6 from Navision. The Problem is that the SQL Statements, that was send from the PHP3 Script will not handeled correctly. But If i use the same SQL Statement (the same Php3 Script, only change the ODBC Connection to the SQL Database) and move the Navision Database on an SQL Server, it works fine ! Now my Question: Where i have to lok for the lack in my Projekt ??? Thanks ALex an SQL Server (just import the Company) ------------ Best regards Alejandro Schubert alejandro.schubert@cycos.com
I would first of all check the options of the ODBC32 Setup. Especially the “Identifiers = All Characters” setting! Marcus Marcus Fabian phone: +41 79 4397872 m.fabian@thenet.ch
I found the bug ,… My PHP3 Code in my first version, was not very fine. Thank, and all works fine ! ------------ Best regards Alejandro Schubert alejandro.schubert@cycos.com
