When attempting to export objects (fob format) from a 2.00a database, I receive the error message “The object file cannot be used with this version of the program”. I have deleted the zup file but cannot determine the source of the error. Any ideas?
This happenes if you try to export the fob’s into a directory which already contains .FOB’s of other navision versions. Example: You try to export 2.00 objects to C:\TEMP\A.FOB but there is already a file C:\TEMP\B.FOB which contains 2.01 or 2.6 objects. Delete B.FOB and you can happily export your 2.00 fob’s ------- With best regards from Switzerland Marcus Fabian Edited by - fabian on 2001 Aug 07 18:44:34
