Does anyone know if Navision Server 2.0 is compatible with Windows Server 2003? I was able to install, but the service will not start properly. When starting the service I get the following error: Could not start the Financials Server service on Local Computer. Error 1067: The proces terminated unexpectedly. Thanks in advance. Bryan
Yes, you should be able to make it work. How big is the cache set, for a start?
