Navin.exe as a service in W2k?
We have just moved from a OS/2 server to a Windows 2000 server. Is it possible to run Navin as a service under Windows 2000? How?
You only need to use the startup parameter ‘installasservice’. i.e.: cache=50000,serverno=1,installasservice
Thanks for the answer.To clear things up: Of coarse it is SERVERN.EXE I meant. Is it the same with that? I hope it is!
