How can i hide the Navision Navigation Pane, Navision ToolBar, Navision Status Bar on Startup from C/AL Code. I need to modify codeunit 1 but actually what code i need to write. Please guys your help is required in this regards with example code please.
Erik is correct, this can not be done direct in C/AL but you can with the Windows Script Host Object Model WshShell - SENDKEY function. SENDKEY acts as if the user is typing in the keys
e.g. ALT-F1 for the navigation pane and ALT-V T for the toolbar (you will then need to send space and down arrow)
