Navigating the Navigation Pane...
Hi, All
maybe this is a silly question, but is there any way to find which branchs of the version 4 menu tree contain a specific object? The Where Used function in the Dev Tool doesn’t seem to cover this particular use. [:(]
Hi Anna,
On mibuso.org you can find a “Menu Suite Analyser” in the download section. May be this tool helps you (a little bit at least).
/Karl
Interesting tool, indeed! Thank you, Karl!
"Freeware, by Christophe Watrelot (cwatrelot@gesway.com), April 2006
Sure you’ve spent some time looking “Where is this $%#&£!!! function!”
  1. ObjectDesigner, MenuSuite, select all MenuSuite objects then Export as txt.
  2. Run form 89040 “Menu nodes”, Functions, Import MenuSuite
    You can choose a language with “Language Filter” flowfilter.
    So, Don’t worry, be happy!"
http://www.mibuso.com/dlinfo.asp?FileID=585
