Navasion 3.7 problem
I have a problem currently that some users will be unable to log into the navision database(I am not using sql). When I launch navision it just hangs at the splash screen and the process must be terminated. any idea what could cause this? The only fix i’ve seen so far is to uninstall and reinstall which is very inconvenient. Also, is there a way to install so that a non-admin user can use it without having to grant temporary admin rights to run the first time?
Try creating a sshortcut to fin.exe onto the desktop. There are a lot of posts ontis topin in the forums, and in the last 2 weeks tere was a very good explanation by someone (sorry forgot who, for an actual fix. Try search.
