Hi, I was Repaired the Operating System In Ls-retail Server(Xp-proff) after that when i run the data replicate from Ls-retail Back Sheduler it is giving a message by saying Server Cannot be Found in the Nav Server system (server 2008 os) is there any body can answer me…
Make sure that :
you have installed the NAV server at the first place.
Make sure you open the NAV instance in Server mode.
3.finally also check in your host file that you have entered correct IP and server name of your NAV server.
I hope this will resolve the issue.
Zamir Gori
Hai Thanks For your Valuable Comment on the same Infact We are going with Complete fresh LS-retail installation…
