Nav on TS with Active Directory
Hello Gurus, I was just wondering if anyone is running Navision (I have version 4 SP3 on SQL 2008) on Terminal Server (2008) with Active Directory? In general they adivce against running Active Directory on a Terminal Server, but I would like to prevent my users from having to login twice (first login to TS then login to Nav). Any suggestions or ideas are much appreciated.
Mark
You don’t need to run Directory Services on the Terminal Server. It just needs to be in the domain. Setup the NAV users with Windows Authentication. They log into the TS with their domain accounts.
