Nav Atain 3.7 on 2003 SBS, Slow startup
I have a MS Server 2003 SBS, running the attain 3.70 exe 2.60 busines logic, Each morning run the client and it takes upto 10 minutes to start, just stays on the first splash screen, same problem on the server and client. then after 10 minutes the login prompt appears and all OK. Even started fine after that. Only happens first thing in the morning. Exchange is running Any sugestions Thanks
Please look at this topic: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=9866
Thanks, this seems to the problem we are experiencing, will give it a try tonight
