Is it possible to instal the navision client on a Windows 2000 server? The instalation says it must be Xp or 2003, I understand it is only officially supported on this but…
Regards
Richard
Regards
Richard
here is a tip from mibuso.com
Thank you it worked and on a Terminal Server as well.
FYI also used regsvr32 to register NSObjectXProxy.dll; ROTAccess.dll; NSAppHandler.dll;Msmapi32.ocx;and Ntimer.dll.
Will search both sites next time!
I just used Orca to edit the LaunchConditions in the MSI installer so it doesn’t check your OS. Then it installs 100% using the installer.
I assume I can follow the same process for windows 2000 workstation addtionally Windows 2000 server?
thanks
I guess so.
