NAV 5.01 SQL2005 synchronisation failed
Hello,
we use NAV5.01 and MS SQL2005 witch ServicePack3. I can´t apply a new user in NAV cause the synchronisation between NAV and the SQL-Server failed. Any idea?
Greetings Thomas
welcome to DUG.
What is the error message…
Please excuse my english translation.
"The security system from Microsoft Dynamics NAV and the SQL Server couldn´t be successfully synchronized.
The SQL Server Login… isn´t present on the Server."
And if I am logged in as a sysadmin on the SQL Server there is an other message.
"the following sql server error occurred.
15138,“42000”,[Microsoft][ODBC SQL Server driver][SQL Server]
The database principal owns a schema-object in the database and cannot be dropped.
SQL:
{CALL[sp_revokedbaccess](?)}
I hope you understand this..
I was able today to solve a similar case:
Please use sql profiler on SSMS and start sync again in NAV. Profiler shows the “bad” user.
After that and still on SSMS–>VIEW–>Object explorer details---->DATABASES(select the Database where your getting the problem)---->Security---->Schemas
From here you can check which owns the schema and change accordingly, that is, removing the “bad user” and reinsert the correct owner. Thai is, if schema is ‘db_datareader’, correct owner should be “db_datareader”.
Hope it helps, regards!
