NAV 4.0 API for .net programming
I know that NAV 4.0 version does not support web services like NAV 2009 version.
This is my first question.
Is there any way or API supported in NAV 4.0 version to implement .net application?
I would be really appreciated if anyone answer me.[;)]
Thanks.
Kevin
If you are trying to run business logic, you can get creative use the message queue with Job Scheduler or retrofit the 5.0 Job Queue
(http://blogs.dotnethell.it/DynamicsNAV/Job-Queue-Concepts-on-Dynamics-Nav-5.0__12550.aspx) (http://www.mibuso.com/dlinfo.asp?FileID=924)
If you want to insert documents (orders, ect), I recomend a temp table in conjunction with a Job from one of the above options.
