NAV 4.0 and 3.7 on the same SQL server
hello,
we use MS SQL Server 2000 and run a 3.7 navision database on it and odbc drivers. now we did an upgrade to 4.01 and I installed the new 4.01 client on a workstation.
when i try to connect to the new database I get an error that the SQL ODBC driver information is old and that i need to upgrade it.
if i do so, will i still be able to access the 3.7 database and all its functionality?
thanks
sonja
Hi Sonja,
If you are refering to the SQL extended stored procedure. xp_ndo.dll. then Yes, it is backward compatible.
Make sure that you have also the recent versions of ODBC and MDAC installed!
