NAV 2017 Compare-NAVAppApplicationObject
I am trying to compare the Original and Modified txt files to create the Delta file and I am getting erros
WARNING: original.txt(1,1) expected.
WARNING: modifiedl.txt(1,1) expected.
Do you have any suggestion how to fix the issue?
Hello,
  1. Dont give NAV-ARCB as foldername instead try to give in one word as NAVARCB and then try.
  2. If you are entering powershell command manually in script, then use the path within double quotes.
It basically tells you that it cannot read the content your files.
Harikiran’s suggestion could also be a solution - it could be that it just can’t find them.
Other wise if the files are open, then try to close them.
Thank you. I was using an incorrect “Save as Type”. The file name was Modified.txt but the “Save as Type” was .fob
Ahh yes, that would also explain it. [:)]
