You should follow the setup for how to use codeunit 88. The use is different to other job queue entries, as it’s part of the “background posting” functionality which have been in Navision since NAV 2013.
Thanks for your reply. Just as you said, background posting is different to others. I remove the Job Queue Entries of CodeUnit 88 and restart the job queue then the background posting runs fine.
But something is still not right. When I post the SO, the Job Queue Status did change to ’Scheduled to Posting’ but then change to ’Posting’ right away. I don’t want this, I want the SO to be posted at the end of the day.
In the second link you suggest, it says: “Microsoft Dynamics NAV creates a job queue entry that specifies codeunit 88. The creation of the entry is automatic.”. Then how can I setup the Starting Time of this Job Queue?
The whole purpose of using the “background posting” is to push the posting to the background, so that the users can continue. Instead the invoice/order is posted at first convenience. So you don’t actually schedule the posting, it just creates a one time job for each invoice to be posted.
What you wanna do is “traditional” batch posting.
But you can do that as well. Then you just need to disable the background posting again, because this you cannot schedule. Instead create a job queue job to run the batch posting reports (report no. 296 etc.).
Did you program something to create those entries? You should just turn on background posting, and NAV will take care of that automatically. Here’s a link that will tell you how to do that: msdn.microsoft.com/…/hh879081(v=nav.90).aspx
