NAV 2016 RTC Error
I have installed NAV 2016 W1 in windows server 2012 R2. While opening NAV 2016 RTC,getting error as-“The Microsoft Dynamics NAV server is currently not ready to serve requests. Try again later or contact your system administrator.”
I already given permissions in SQL server for NT “Authority/Network Service” login as a db_owner to my database. But still getting same error.
Please suggest me the solution.
Baba Guru.
Please check event viewer. you may find more details
I solved this by going to Nav admin , go to the instance that is hopefully running ( that’s another issue ), open the database section and look at database name. In My case it wasn’t filed in ( well done Microsoft !! ) even though I’d take all MS defaults.
