I have a simple table Job Shift, it’s primary key is a Job No. and a Date.
In a cue table I have created a flow field counting the number of records in the shift table.
As soon as I apply the date filter to the flow field, then the client crashes with this message:
Problem signature: Problem Event Name: CLR20r3 Problem Signature 01: Microsoft.Dynamics.Nav.Client Problem Signature 02: 9.0.45834.0 Problem Signature 03: 5723b44c Problem Signature 04: Microsoft.Dynamics.Nav.Client.WinClient Problem Signature 05: 9.0.45834.0 Problem Signature 06: 5723b446 Problem Signature 07: 5d Problem Signature 08: 80 Problem Signature 09: FatalError OS Version: 6.3.9600.2.0.0.400.8 Locale ID: 1030 Additional Information 1: d965 Additional Information 2: d96505cc22c28e6ffaca984aa0afd61f Additional Information 3: 370c Additional Information 4: 370cd3a13a5f120686575451bc89d624
As you can see then I have even applied the latest cumulative upgrade 7 to check that it wasn’t a problem that was fixed.
The problem also occurs when running the table object directly and applying the date filter manually.
Type: System.InvalidCastException Message: Specified cast is not valid. StackTrace: at Microsoft.Dynamics.Nav.Client.WinClient.ExceptionHandler.<>c__DisplayClass6.b__4() at Microsoft.Dynamics.Nav.Client.WinClient.NavClientErrorHandler.ExecuteAndCatchExceptions(Func1 execute)* *at Microsoft.Dynamics.Nav.Client.WinClient.ExceptionHandler.DoExecute(Func1 execute) at Microsoft.Dynamics.Nav.Client.WinClient.ExceptionHandler.DoRethrowWithCatchException(Exception exception, Boolean designMode) Source: Microsoft.Dynamics.Nav.Client.WinClient HResult: -2147467262 ---------------------------------- Type: System.InvalidCastException Message: Specified cast is not valid. StackTrace: at Microsoft.Dynamics.Nav.Client.Formatters.NavBaseDateTimeFormatter.ValueToStringInternal(Object value, LogicalControl control, IFormatProvider formatProvider, Boolean displayFormat) at Microsoft.Dynamics.Nav.Client.Formatters.NavBaseDateTimeFormatter.ValueToString(Object value, LogicalControl control, IFormatProvider formatProvider) at Microsoft.Dynamics.Nav.Client.UIPatterns.CaptionManager.GetFieldStringFromValue(NavBindingManager bindingManager, String stringFieldId, Object fieldObject, IFormatProvider formatProvider) at Microsoft.Dynamics.Nav.Client.UIPatterns.CaptionManager.BuildListDynamicCaption(NavBindingManager bindingManager, IFormatProvider formatProvider) at Microsoft.Dynamics.Nav.Client.UIPatterns.CaptionManager.BuildDynamicCaption(LogicalForm form, NavBindingManager bindingManager, IFormatProvider formatProvider) at Microsoft.Dynamics.Nav.Client.UIPatterns.CaptionManager.UpdatePageCaption(LogicalForm form) at System.EventHandler.Invoke(Object sender, EventArgs e) at Microsoft.Dynamics.Framework.UI.BindingManager.ChangeStateToFilled() at Microsoft.Dynamics.Framework.UI.BindingManager.DoFill(DataReaderFillOptions fillOptions) at Microsoft.Dynamics.Framework.UI.BindingManager.Fill(BindingManagerFillOptions options) at Microsoft.Dynamics.Framework.UI.LogicalForm.LoadDataInternal() at Microsoft.Dynamics.Framework.UI.LogicalForm.LoadData() at Microsoft.Dynamics.Framework.UI.Windows.LogicalFormAdapterBase.OnLoadData() at Microsoft.Dynamics.Framework.UI.Windows.LogicalFormAdapterBase.LoadDataInternal() at Microsoft.Dynamics.Framework.UI.Windows.LogicalFormAdapterBase.Load(LogicalControl originatingLogicalControl, Boolean loadDataDelayed) at Microsoft.Dynamics.Framework.UI.Windows.ClientSessionBase.OnFormToShow(LogicalForm logicalFormToShow, LogicalControl originatingLogicalControl) at Microsoft.Dynamics.Framework.UI.WinForms.ClientSession.OnFormToShow(LogicalForm logicalFormToShow, LogicalControl originatingLogicalControl) at Microsoft.Dynamics.Framework.UI.UISession.OnFormToShow(FormSessionEventArgs e) at Microsoft.Dynamics.Nav.Client.PageRunCallbackHandler.RunPage(FormRunRequest formRequest) at Microsoft.Dynamics.Nav.Client.ServiceConnection.ProcessServerResponse(Object response) at Microsoft.Dynamics.Nav.Client.ServiceConnection.CallServer[T](BeginCallServerMethod beginCallServerMethod, EndCallServerMethod`1 endCallServerMethod) at Microsoft.Dynamics.Nav.Client.ServiceConnectionBase.DrilldownField(NavRecordState& state, NavDataSet recDataSet, Int32 controlId) at Microsoft.Dynamics.Nav.Client.DataBinder.NstDataAccess.DrillDownField(String personalizationId, String controlName) at Microsoft.Dynamics.Nav.Client.Actions.NavDrilldownAction.InvokeDataAction(LogicalControl logicalControl, UISession uiSession) at Microsoft.Dynamics.Nav.Client.Actions.PageDataAction.InvokeCore(LogicalControl logicalControl, Object state, UISession uiSession) at Microsoft.Dynamics.Framework.UI.LogicalAction.InvokeCoreWithErrorHandling(LogicalControl logicalControl, Object state, UISession uiSession) at Microsoft.Dynamics.Framework.UI.LogicalAction.DoInvoke(LogicalControl logicalControl, UISession uiSession) at Microsoft.Dynamics.Framework.UI.ActionControl.Invoke() at Microsoft.Dynamics.Framework.UI.Windows.ActionsHelper.ModalitySafe(Action action) at System.EventHandler.Invoke(Object sender, EventArgs e) at Microsoft.Dynamics.Framework.UI.WinForms.Controls.Stack.OnMouseUp(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) Source: Microsoft.Dynamics.Nav.Client.UI HResult: -2147467262
is the date field of type date or datime ? the exception shows that the values are formatted to a datime internally. try both types date and datetime. if that does not work, try with integer fields for day,month,year. maybe its a problem that a date field is part of the key.
