NAV 2016 Customer/Item Statistics report
Can anyone tell me what table or tables this report is pulling from. I know it’s grouped on item Number.
Go to the Object Designer---->Open the report in design mode and you will see the primary tables. If you go to View—>Globals you will see other tables other than primary tables and you can go to the code and see what values are being pulled into the report.
