NAV 2016 AU. F1 Help failed to load on Explorer Edge and IE in Windows 10
Has anyone encountered problem loading F1 help.
We tried on Windows 8.1 computer . Same problem exists.
did you install help server while installing NAV2016?
check if the help components were installed (help server, …) and if it is correct configured.
