NAV 2013 report
I am running a report on routing lines that are currently in production and everything seems to be working fine the only problem is the line is duplicating itself 20 or 30 times before it moves on to the next routing line. What am I missing in there to make it only show that routing line for that order only once.
Kyle
Hi! Sounds like data item definition / link in the report structure. Is it standard Nav 2013 report? If so what is the report number? Also presume you are using US version of Nav 2013?
Neil
It is a basic custom report I built.
Kyle
Ok so look at data item links as the issue will be down to report structure I would have thought. Difficult to advise without seeing the report design. I can have a quick look if you email the report object to me neil@fpconsult.co.uk.
Neil
