admin1
1
I have a strange problem with a NAV 2013 R2 report.
The report has three tablix in the same retangle in this order.
LineTablix
TotalTablix
DateTablix
The issue is when printing the report, then it’s printed in this order:
TotalTablix
DateTablix
LineTablix
What am I doing wrong?
Hi Erik,
Can you please explain more about the question… I mean What properties did you given for that three tablix…
Mahesh U
admin1
3
The main problem was solved by moving the tablix’ into a rectangle.
But the correct thing to do (?) would have been to add a “list” and then add the tablix to this (in order for it to print each customer separately).
But when I’m doing this (adding the “list” and cut/paste the tablix’s into the list/rectangle), then I’m getting this error:
"The tablix “tblCustomer” has a detail member with inner members. Detail members can only contain static inner members."
It’s something to do with the grouping, but can anyone explain what this means?
