I’m here because I’ve a not common error when i use the CREATETEMPFILE, the error is this:
“Either the caller does not have the required permission or the specified path is read-only.”
I have checked that users has permission for the Temp Path… Also I have restarted service and server…
You can help me? Thank you,
PS: Also I have checked the I can export the pages to excel,word withouth problems… So why this is normal and the other no?.. They are both saved in the same Temp Path…
Check that your NAV instance service user have rights to create and write files in your NAV servers ProgramData path. Typically: “C:\ProgramData\Microsoft\Microsoft Dynamics NAV\71\Server<instance name>\users\default”.
