May I know how to display the default field in request form?
I write this code but it doesn’t work:
SETFILTER(“External Document No.”, “G/L Entry”.“External Document No.”);
Please help.
Thanks in advance.
Please help.
Thanks in advance.
You cannot write code in the “Add Filter”. But try to put this filter on the On"PreDataItem" of the “G/L Entry”.
You want to show the field only or value also?
You can add fields in ReqFilterFields property of dataitem…
I need to display the default field, value will be selected by user.
However I have solved this, I assign field to Properties → ReqFilterFields
Thanks all @
