NAV 2009 Windows Server 2008 x64, SQL2008 : xp_ndo_x64.DLL
i’m facing a problem when adding the new stored procedure in SQL
i select the path of xp_ndo_x64.DLL and press OK,
when reviewing again, it will show without the path.
any idea why that is happening?
In witch folder are you placing DLL?
hello nuno,
i cannot see BINN, because it’s on the C:\ (clustered), so i’m placing it on the D:\
