Nav 2009 r2 report shows blank pages
I have create a customized report on nav 2009 r2 but when i run that report with some filters then its working fine.
But the problem is when i run that report without filters then report shows bank page only shows caption on RTC(But its run proper on classic). On report minimum 1.5 lakh lines are there.
Can anyone have an idea about this.
Thanks in advance.
So you should have to apply some filter conditions on RTC report the way you tried to run it.
Hello Pravin, Try on Report Request Page- Help → Info about this Page → It should Show the dataset in the second try. There you can verify the Data . May be there is a Problem with your DataSet. Regards, Rexoni Joseph
