I need a help regarding this issue.
I’m restoring a database from FBK file. After a long time restoring the database, suddenly this error message occured when it’s almost done.
What’s the cause of this and is there anything i can do to complete the database restore process ?
Edit : For more information, i’m using NAV 2009 R2 build 32012
What are you restoring? A full database or a single company?
It looks like you’re restoring a database or its application objects into an existing database, where the database schema for your Payment Terms table has been changed (as Imran wrote).
Hi Imran & Erik, i’ve found the cause. It’s because the payment term table have a record that isn’t supposed to be there. I don’t know how the customer insert them in the first place, but it’s all sorted out now.
