I am new in Nav development. Currently I faced the problem of date development.
I would like to know how to add the month to a date and get the result.
For example:
employdate:= 01-01-2014;
ProbationPeriod := 3;
endofprobation := employdate + ProbationPeriod; //result: 31-03-2014
Please help. Thanks.
hi,
newDate := CALCDATE(’-CM+3M-1D’);
Thanks Jonathan for the solution. this is work!
By the way, another question, do you have idea how to set the range by select only the month? I need it to generate the report.
For example,
month: 10 //selected by user
Then fixed the date which is 21/9/2014 to 20/10/2014. (21st and 20th is fixed while month is selected by user and year is current year)
Thanks in advance.
warmest regards
joan
currYear := DATE2DMY(TODAY,3);
startDate := DMY2DATE(21, Month - 1, currYear);
endDate := DMY2DATE(20, Month, currYear);
you’ll only need some additional code, if Month = 1 (i.e. January, so Month -1 = 0 → 12/ last year).
