NAV 2009: Export a list of contacts to XML instead of Excel or Winword
you may export a list of contacts, i.e. contained in a segment, to Excel.
I’d rather like to export the contacts to an XML file instead.
Is there a way to do this?
Sasch
Yes, you must use an XML Port for this.
Hello,
thanks for the information. I have found a number of XML ports using the classic client. One of them is the Export Contact. How do I use it from RTC to export a contact?
Sascha
you need create a Codeunit with code like
XML.CREATEOUTSTREAM(outstr);
POXMLPort.SETDESTINATION(outstr);
POXMLPort.EXPORT;
and run the codeunit in RTC
I’m going to try it.
