The microsoft Dynamics NAV server cannot connect the change listener to SQL server due to the following error Cannot open database"Demo dtabase NAV(6-0)" request by login. The login failed for the user’NT Authority \Network Service’.
I am using NAV 2009 with SQL server 2008.
Did already search this forum? This issue has been asked about various times.
Harish,
Also please read: http://dynamicsuser.net/content/how-to-ask-a-question.aspx before posting! Search before posting and use an subject who tells the reader what your problem is about.
Check with config.xml file, whether database or sql instance is correct.
Cheers,
