NAS Services
HI All,
When i am trying to start NAS services i am getting this warning message.
Can anybody please clarify why i am getting this message.
The description for Event ID 20010 from source cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Job Scheduler Mgt. Setup Primary Key ‘’ does not exist.
the message resource is present but the message is not found in the string/message table
Is there a record in the Job Scheduler Mgt. Setup table?
No there is no record in it.
Well…since that’s the error message you got, that there is no record there (i.e. you haven’t setup the Job Scheduler), you should probably try that.
Thanks. now it is working.
and how you solve it? I can’t find Job Scheduler Mgt. Setup table
