NAS / Navision Application Server problem
Hi Everyone,
I am facing a problem while interaction with NAS.The thing i want is a text file should get generated without any user interaction for this i am doing the following steps.
I have created a Codeunit in which i have wrote a small fuction for the creation of text file in c:. After that in codeunit 1(Application Management) in function NAS Handler
i have written the code for calling the above Codeunit but it will not creating the text file in c:
Can anybody help me out.
PR: wait… I: wait… L: wait… LD: wait… I: wait… wait… Rank: wait… Traffic: wait… Price: wait… C: wait…
What I would do:
Create a new codeunit that is singleinstance. I would put a Navisiontimer DLL (‘Navision Timer 1.0’.Timer) in it with property “WithEvents”=Yes.
This creates a new function “autNavisionTimer::Timer(Milliseconds : Integer)”.
In this function you put the code (=a functioncall : eg. : “CreateTheFile()”) to create the file.
In the OnRun-trigger, you must put some code to enable the timer. Something like this:
CREATE(autNavisionTimer);
autNavisionTimer.Interval(recDownloadSetup.“NAS Timer Interval (s)” * 1000);
autNavisionTimer.Enabled(TRUE);
autNavisionTimer.Interval(timerinterval in milliseconds);
CreateTheFile(); // in case you want to create the file immediately when you launch the NAS:
And in codeunit 1 : launch this codeunit.
Hi kriki,
Thanks for your reply.
I have followed the above steps as told by you.
I have created a codeunit and set its property to SingleInstance and its onrun event i have put the following code.
autNavisionTimer.Interval(1000);
F.CREATE(‘C:\TEST.TXT’)
In the above code F is file type of object.But now my problem is in Codeunit 1 where i have to put the code if in NASHANDLER than how i have to call the timer codeunit. If you can send me the sample of code then it will be good for me.
You must insert into codeunit 1 in function NASHandler.For example, to start ADCS it’s checked correct parameter.
“IF (COPYSTR(Parameter,1,4) = ‘ADCS’) THEN BEGIN”
You must insert a similar check for your string and insert it as start-up parameter for your NAS
Hi kriki,
I have inserted the code in code unit1 nashandler function but still file is not getting created.
After starting the service of NAS in Event Viewer i am finding a warning message i am pasting that message below.
The description for Event ID ( 20010 ) in Source ( RAVISHANKAR-CLASSIC ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: The network path cannot be found.
This message refers to the file .
The network server may be down, or the path may be invalid.
can you please see that problem and tell me where i am doing wrong.
Sorry it took so long to answer, but I have been on vacation and since I came back to work, I have been very busy.
Check if the login you use has Windows-permissions to write the file.
