Due to some technical problems with URL forwarding, the site is only available using the following address: http://213.224.79.247:38001/navision Don’t put this address in your bookmarks! It will probably change. I’ll let you know when the site is back available using the domain name. Alternatively, you can use www.mynavisiondamgaard.net to access the site as well. Regards, Luc Van Dyck webmaster myNavision.net Edited by - LucVD on 2001 Apr 09 08:22:23
The technical problems are solved! You can access the site using the domain www.myNavision.net Regards, Luc Van Dyck webmaster myNavision.net
