Multiselect Enum Parameter Field show number instead of Name
public void lookupJobCardType(FormStringControl control) { SysLookupMultiSelectGrid MSjobCardType; Query query; QueryBuildDataSource qbds; counter counter; MSjobCardType = SysLookupMultiSelectGrid::construct(control,control); query = new Query(); qbds = query.addDataSource(tableNum(ACX_JobHeader)); query.dataSourceTable(tableNum(ACX_JobHeader)).clearRanges(); query.dataSourceTable(tableNum(ACX_JobHeader)).addSelectionField(fieldNum(ACX_JobHeader,JobCardtype)); qbds.addSortField(fieldNum(ACX_JobHeader,JobCardtype)); qbds.addOrderByField(fieldNum(ACX_JobHeader,JobCardtype)); qbds.orderMode(OrderMode::GroupBy); MSjobCardType.parmQuery(query); MSjobCardType.run(); }
Does any Buddy know the solution ?
Can you please use Insert > Insert code to paste source code? The thing above is unreadable, because it lacks line breaks and indentation.
By the way, I moved the extra keywords from the title to tags.
    Query                       query;
    counter                     counter;
    MSjobCardType.run(
This is UI Builder Lookup Method
Let me simplify it a bit, so it’s easier to follow.
    SysLookupMultiSelectGrid    msJobCardType = SysLookupMultiSelectGrid::construct(control,control);
    Query                       query = new Query();
    QueryBuildDataSource        qbds = query.addDataSource(tableNum(ACX_JobHeader));
    query.dataSourceTable(tableNum(ACX_JobHeader)).addSelectionField(fieldNum(ACX_JobHeader, JobCardtype));
    qbds.addSortField(fieldNum(ACX_JobHeader, JobCardtype));
    qbds.addOrderByField(fieldNum(ACX_JobHeader, JobCardtype));
    msJobCardType.parmQuery(query);
    msJobCardType.run();
