I am installing multiple AX 2012 AOS instances in a single server which will be used to connect to multiple SSRS Reporting Services instances. Just like the one from TechNet : http://technet.microsoft.com/en-us/library/hh389760.aspx
However after modifying reporting services configuration files (I’ve narrowed down the problem to RsReportServer.config file) I cannot start the Reporting Service instance and instead it gives me an error in the Event Viewer:
Service cannot be started. System.Exception : Default appdomain failed to initialize.
at Microsoft.ReportingServices.Library.ServiceAppDomainController.Start()
at Microsoft.ReportingServices.Library.ReportService.OnStart(String[] args)
at System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(Object state)
Where did I go wrong?
Thanks in advance.
