Multiple SO selection info display issues
Hi Seniors,
We have a issue here,
  1. Selected both Sales Order
  2. Included Shipment Price in both Sales Order
  3. First SO Shipment Price displays in Report
  4. Second SO Shipment Price does not display in Report
  5. Total amount for both SO Shipment Price displays Correctly
Below is the screenshot and coding::
///////////////////////////////////////////////////////////////////////////////////Code///////////////////////////////////////////////////////////////////////////////////////
display SalesPrice PRS_getShipmentPrice()
SalesLine _salesLine;
select firstFast PRS_ShipmentPrice from _salesLine
where _salesLine.SalesId == CustPackingSlipTrans.SalesId
&& _salesLine.ItemId == CustPackingSlipTrans.ItemId
&& _salesLine.InventTransId == CustPackingSlipTrans.InventTransId;
return _salesLine.PRS_ShipmentPrice;
/////////////////////////////////////////////////////////////////////////////End Code///////////////////////////////////////////////////////////////////////////////////////
PRS_ShipmentPrice Code:
forms/SalesTable/DataSources/SalesLine/Fields
public void modified()
super();
ttsbegin;
if (SalesLine.SalesDeliverNow != 0)
SalesLine.PRS_CustomPrice = SalesLine.SalesDeliverNow * SalesLine.PRS_ShipmentPrice;
else
SalesLine.PRS_CustomPrice = SalesLine.SalesQty * SalesLine.PRS_ShipmentPrice;
ttscommit;
Please Advice.
Bongcs
Anyone ?
Update From Anyone ?
Keywords: firstonly10 does not work.
You need to debug the shipment price method in the report to see what is wrong, whether you were able to get the correct packing sliptrans.
Hi
You have to modify the query below :
to
where _salesLine.SalesId == CustPackingSlipTrans.OrigSalesId
So, you have to use OrigSalesId field.
SalesId is the first Sales Order involve in the posting and AX use for relation with the CustPackingSlipJour
Regards
Feedback:
Hi Denis & Kranthi,
//////////////////////////////////////////////////////////////////////////////////////////Code//////////////////////////////////////////////////////////////////////////////////////////////////////
///////////////////////////////////////////////////////////////////////////////////////End Code//////////////////////////////////////////////////////////////////////////////////////////////////////
The Amendment of the following from keyword:
SalesId > OrigSalesId
Has proof to be a success.
Below is the screenshot:
Appreciate the knowledge that you’ve shared, Thanks Very Much.
Bongcs
Great
Remember to set the post as verified solution
