Select multiple records by check box on a form and click on menuitem button so that it should create a report for those selected record only
Challenges: for one selected record it is working but i need if it multiple record how can capture those records and pass through a menuitem. Please help me on this requirement
after fetching the mutiple selected records from the form… take a tempoarary table( duplicate of the table which You are fetching data currrently)…
and insert all the records that are fetched using the above code to temp table…
provide the tmp table as datasource to the report… and delete the data from the table whenever the generate report button is clicked… so that new data will be inserted…
