I have a shipment template with value ‘Same customer’ Print picking list in sales order (Invent model group : Use output order). Although sales order belongs to different customers, the output order is combined in the same shipment. Any idea? Regards, DJ
Joint picking is about the way the inventory is picked, but not the way the shipments are created. So if you create Shipment template with Same customer as Joint picking criteria the newly created shipments will include all the shipment orders, which satisfy the selection criteria. And only when you will activate shipment and system will create picking routes the Joint picking criteria will be considered and it will affect the number of picking routes created. If you setup Same customer as Joint picking criteria there will be created at least one picking route for each customer even if shipment contains shipment orders for several customers. I hope, it is clear for you. Glibs
