Multiple Locations per Production BOM
Has anybody developed a modification that allows different Production BOMs per location (using Manufacturing)? We were planning on developing our own mod using the Stockkeeping unit cards to assign the BOM/location combination to the item number but was wondering if anybody has already looked into this and came across any problems.
Hi Kris You may get a repsonse from this in either the add-on forum or some thoughts from developers in the developer forum. I would not like to comment on how easy or difficult this would be!
Assuming you move this to the Developer Forum … [;)] It should actually be an easy piece of custom. You will only need to change how the BOM Number is loaded into the Prod. Order Header. Once it has been loaded, all the existing Refresh, etc. functionality can be run (which is the hard part, so not touching this is nice).
The developers are invading the other forums - run, run for your lives . . . . . . . . [:D] Thanks for the input Chris.
Don’t forget the Version Management codeunit that is used throughout Manufacturing. And the Create Production Order from Sales Order functionality. And MRP. And a bunch of other places. [:D]
