Multiple Field Usage
Hi All ,
what is the use of the Multiple field in Default order settings in the Item Master ?
Could please explain with an example.
Thanks in Advance.
It can be related to purch/inventory/sale. The number says, how many times must be order quantity multiplied. Acutally the system is not that restrictive. The system warns you, that qty is not multiple of lets say 3 and you can accept/reject rounding.
Example: Multiple for purch order is 3. Purchase quantity can be only 3,6,9,12,15… (multiple of 3).
Thanks for the explanation .
Still i did not understand your example .
In My database one item has in Default order Settings - Sales order - Multiple is 2 . Now when i create the sales order for 11 PCs for that item . System is throwing the message like
Multiple of 2.00 only.
Quantity here is 11.00 only
Rounded up to 12.00 .
My question how is rounding to 12 , I am not getting this rounding concept .
Please explain.
In your example: 11 is not multiple of 2, thats why the system warns you. The closest multiple of 2 is either 10 or 12. The AX rounds to higher value in this case…
