Multiple Applications on one server
I have been trying to create two separate web sites for two separate companies in Enterprise Portal. The two companies exist in two different environments (different databases, different AOS, different configuration utility setups) but are still on the same server. The problem arises when you try to create a new “Shared” projects in order for the web sites to use. This “Shared” folder apparently allows sharing between the two environments, which is a little surprising. Does anyone know a way to separate these files so that there is no crossing of the data? The only thing that I could think of is to create two totally different applications on the same server, something that Axapta doesnt allow. Does anyone know a way to get around this??
